105 series dash problem
Jye
australia
hello guys can someone shed some light on 105 series dash problems. no gauges are working and wondering what might be the problem?
thanks
Can't help i'm afraid but watching this one. The gauges on my 105 dont really work to well either. The sub tank fuel gauge doesn't work at all, the oil pressure gauge can't be trusted and the main battery volt meter is iffy at best.
At a guess, if you've checked fuses inside and under the bonnet and looked for any loose earths bolted in the footwells (they are on 80s so this is a guess) then I believe there is a voltage regulator somewhere that controls the voltage to the instruments. This may be at fault. Couldn't tell you where to look though but under the dash or at the sides of the footwells are likely spots.
Good luck with it.
Oh, and welcome BTW. This section is really just for saying Hi and telling us a bit about your cruiser. You may get more help by posting your question in the 105 series section.
