1HD-FT Emissions control manual ERM111E
nielsc May 7, 2018
  1. hopeless wanderer
    hopeless wanderer Well-Known Member I am in england
    650
    381
    63
    Map
    Cheers for that, I'm concerned the new MOT and rules regarding warning lights may pose a problem if the the tester is being a bit strict. I've got the gist of it I think and I need to cut the two wires shown in the two plugs and the heater warning goes off. Has anyone tried this ?
  2. Brett
    Brett Well-Known Member I am in uk
    445
    16
    38
    Map
    I've removed my heater, no lights on at all.
    hopeless wanderer likes this.
  3. hopeless wanderer
    650
    381
    63
    Map
    I took out the egt and all the remaining vac/boost hoses. Just boost going to the wastegate & compensator on the pump and to a boost gauge. Lights been on ever since.
  4. Brett
    445
    16
    38
    Map
    did you connect an earth bond from the blanked off intake pipe (where the EGR valves were) down to the block?
  5. Towpack
    Towpack Well-Known Member Supporter I am in england
    3,066
    814
    113
    Garage:
    Map
    On 1HD-FT there will either be vacuum or atmospheric pressure below the pump diaphragm depending on the position of the solenoid. Inceasing the vacuum below will have the same effect as increasing the boost pressure above and vice versa. The vacuum will be applied to offset low boost lowdown in the range, gradually being reduced as boost increases, hence operation being ECU controlled. This is no doubt partly for emissions as much as performance but I don’t see how you can get it to run correctly with the OEM pump and the vacuum supply either disconnected or connected permanently. I removed the EGR valves and manifold some time ago leaving the wiring connected and the vacuum hoses blanked off but I’ll probably have to refit it (deactivated) for the next MOT.
  6. hopeless wanderer
    650
    381
    63
    Map
    I got rid of the whole crossover and the intake heater as I fitted a front intercooler. The doohickeys that were attached to the crossover are just hanging around annoying me.
  7. chapel gate
    chapel gate Well-Known Member Supporter Promoted Company I am in england
    3,165
    1,837
    113
    Map
    would anyone be so kind to translate this?:icon-biggrin:
    I did pose the question. the manuals are still available.
    in Japanese.....
  8. Brett
    445
    16
    38
    Map
    you can use google translate & translate the whole page. It comes out sort of like English!
  9. chapel gate
    3,165
    1,837
    113
    Map
    I tried briefly brett. it all went horrible wrong. it doesn't take much for me to lose my rag with computers, devices, tablets, phones, flux capacitors.. etc etc..
    Brett and hopeless wanderer like this.
  10. nielsc
    nielsc Member I am in belgium
    180
    80
    28
    Map
    I have finally come across this manual, it is in Dutch tough but I can translate if anyone wants information out of it.
Share This Page
    Dismiss Notice
