- Jul 1, 2013
Hi folks,
The manual on this says regular oil service to be done every 3k miles, the engine oil is marked as 'replace' with filter every other service. If driven for mostly short journeys, dusty tracks or under heavy load, this number drops to 1.5k miles. Seems a bit short ?? But how much of this is down to oil quality back in 2001? What do the present day 1hz manuls say about this?
Also the recommended oil is 10w30/semi synth. Toyota in the EU do not sell this oil. What oil are you guys running? What do you recommend ?
