I'm not too sure what those ground wire controls but it was clear in my case that over a matter of couple months it had chewed up the trans. In my case, when the first head cracked, I took it to a shop that swapped a low mileage import engine into it. They however forgot to tighten down those earth cables and couple months of wondering why the trans wouldn't function probably led to that discovery. However, it was too far gone and the trans got re-built. Such a simple mistake led to a hefty repair bill.
Auto trans aren't as complicated as I once thought, but I imagine it's the clutches that go. I don't see how the solenoids can fail. They aren't known to unlike other box manufacturers. The clutch packs themselves aren't too expensive, but it's the labor that jacks up the price with such a repair.
IF the box is truly messed up, you're best finding a cheap second hand box. However, I see you're not from the UK and this may be tough for you to source. Do remember that these boxes are in tons of other trucks too. Box code is A343F.
- 1990-1996 Toyota Hilux Surf 4x4 - 2.4 & 3.0 (4x4)
- 1993-2014 Toyota Land Cruiser Prado (3.0l,2.7l)
- 1995-1997 Toyota Land Cruiser 80-series (4x4)
- 1998-2001 Toyota Land Cruiser 100-series (4x4)
- 1996-1998 Lexus LX 450 (4x4)
- 1998-2002 Lexus LX 470 (4x4)
- 2005-2014 Toyota Fortuner V 2.7 At (4x4)
According to Wiki.
Ok.... Problem and always a solution.
Thanks Beau good info as always. I have sourced one when I added the 4x4 chain and honestly I will buy it just to have the parts. But later would be grater...
Here's what happened in my case..
Friday jumped in after work and it was a bit sluggish in Reverse. (Slight)
Saturday outing by the lake, it was even more apparent that something was wrong. (backing up for a view..)
On the way back, a tempting shortcut got me stuck in the mud...
So I threw it in N, shifted into L and got a little deeper in the mud.. R or D was just slipping.. Pretty much ran through all gears..
No winch.... Right front tire about half way. Left rear tire the same..
So... Jacked that left side and propped under the tire. (ground looked like a walk over)
Was in the process of digging and ready to try and prop the right front side when help arrived...
This is when I realized I needed to add some toys....(winch is a must)
So I'm out..Or am I... Still needed to get through shallow water to get back to the road...
Back on the road and the headache starts.....
I drive for about 500 yards, and can feel the revs increase but the torque is gone...
Stopped turned off the engine, and checkout under the hood and under carriage..
No water in the oil or Trans. No visible leaks.(1 that we'll talk about later. intercooler venturi hose is for hilux)(original-17341-67010).
Started and check trans for water. No smells as if something burned.Started fine,perfect actually.
Again we're off....
After a short lived yeaaah..
Same thing happened few mins later..
Pulled over turned off.. Checked everything I could think of...
Didn't know about the earth wire nor did I see the one wire cut..
I had to repeat this process to get home.....(motel for the night)
In the AM drained the trans and refilled with Toyota ATF T-lV..
Oil looked a bit dark.(no water or foam)
Ok so oil changed and 2miles to house...Made it half way and i had to stop and restart to continue.
struggled to climb off the road (asphalt) into the flat driveway..
And that's where I'm left.... It wont budge either gear or direction...
The work that I've done so far is cleaned all the connector plugs for the trans, repaired that earth wire and changed the alternator fuse. drained the trans again.(drained to set the proper level)
But when i saw and smelled the oil (light burn smell) Ive decided to let it drain completely.
I bought fresh blood for the trans(again) but I'm now thinking i should add a new filter and check whats happening under that trans pan....
Does the solenoid that assists with the pressure also have a little strainer on top?
Engine starts fine. (haven't started at the moment)
Thanks for any suggestions as I'm sure all of you here know that feeling of looking through the window and seeing your, "joy" just sitting there injured....lmao
