G'day All,
Looking for thoughts on installing Bushranger spot lights. They come with a wiring harness and controller, only need a high beam signal wire, otherwise they are pretty straight forward.
Thinking of using a fuse tap on the LH High beam fuse as the signal wire.
https://www.autobarn.com.au/narva-add-a-circuit-twin-mini-blade-fuse-holder
Anyone got any thoughts on this as I see most people seem to talk about tapping a wire of the headlight loom instead?
Isaac
Isaac
