70 series parts for 40 series ?
Mick Zilm May 16, 2018
  1. Mick Zilm
    Mick Zilm New Member I am in australia
    26
    2
    3
    Map
    hi I was wondering if I got my mates 70 series cruiser he said he will sell me cheep if I could use the gearbox diffs etc for my 1962 fj40 for the front discs and 5 speed box . I was hoping to swap complete diff and stealing racks any info would be appreciated I can get this 70 series for pretty much nothing ( a carton of beer ). So I will grab it anyway so if anyone's after any parts I can't use let me know
  2. Rodger
    Rodger Well-Known Member
    960
    385
    83
    Map
    Hi Mick,
    Is your buddy's 70 a Bundera? If so: "Light Duty (Called "Bundera" in Australia, Prado in Japan, Land Cruiser II in some markets) - 70 Series with the smaller engines, lighter axles (with the 8" ring gear) used in Hilux/pickup/4Runner/Surf" according to cruiserfaq
    If you get the VIN number that will give to spec and then you'll know if it will work.
    Post the VIN on here and we'll tell you more.
    Rodger
  3. Mick Zilm
    26
    2
    3
    Map
    Not too sure I will go check it out tomorrow arvo get more info and vin what about gearbox and transfer case guessing that would be light as well ? Mine runs fine and has 4 speed but has a bit of slop in transfer shifter (left /right) and worried with the 253 won't last too long do you know what my original diffs would be my vin is 2-FJ40-16899 any info would be great I find it hard to find out much at all also would love to track down my original engine if it's still around anywhere it's no is F-175236 I will get back to you with my mates 70s info thanks again Rodger
  4. Rodger
    960
    385
    83
    Map
    Hi Mick,
    Info is hard to find but but I shall continue to look...
    Your original engine was an F mated to a 3 speed g/box (3 on the tree as floor mount was available till '64 and then as an option). There is a 75-100% chance that your truck's got 4.11 gears and an H42 or J30 transmission as most F engined LCs were to that spec.
    Your buddies 70 may turn out to be a proper 70 and not a light duty but that's what the VIN will tell us.
    Rodger
    Mick Zilm likes this.
  5. Ben
    Ben Well-Known Member Supporter Guru I am in australia
    5,987
    1,296
    113
    Map
    The light duty 70's are actually pretty rare here so I would be surprised if it was one, but it could be.
    Where as the 75 series utes and troopy's are everywhere, theres millions of them around and the older ones are very cheap now indeed. :think:
  6. Mick Zilm
    26
    2
    3
    Map
    Sorry for the miss information but my mate got it a bit wrong his cruiser is a 1992 60 series vin was hard to read but I think it's FJ-60-048932
  7. Rodger
    960
    385
    83
    Map
    According to that VIN it's a August 1982 60 series, 2F (4.2) with a 4 speed transmission. It is either designated RG-KQ (G wagon with lift up back door) or RV-KCO (standard roof with swing out back doors)
    60 series are all heavy duty, axles are 60mm wider but have discs on the front. Transmission will be strong enough.
    My 40 has a 60 series diesel , trans, axles and power steering.
    You were thinking of using the trans - it will work and for the price - just too good to refuse.
    Rodger
  8. Mick Zilm
    26
    2
    3
    Map
    Thanks Rodger i looked at it today and gearbox and transfer both select all gears /hi/Lo range very smoothly it also had five gears ?? So not sure if it's original box or no
  9. Mick Zilm
    26
    2
    3
    Map
  10. Mick Zilm
    26
    2
    3
    Map
    I
    f
    if axles are longer will wheels stick outside of guards if I use these ? I would like to use the disc break front end if possible
  11. Rodger
    960
    385
    83
    Map
    I'm using the 60 series rims - 15x8 with 10.5 width tyres and added small flares just to be legal ( very strict in Spain) but using slightly narrower rims/tyres you should be okay. It is only just over an inch each side so you should be able to measure that against your current set up. Since the attached photo was taken I have got the left wing sitting better (level) and that meant that I could have got away without the flares (but only just).
    The front bodywork is off mine at the moment but when it's back together I'll photograph it to show you, a couple of weeks or so.
    Rodger
  12. Mick Zilm
    26
    2
    3
    Map
    Very nice rig my wheels ar are right on the legal limit atm so flares might be the go I will go pick up the 60 in next few days and strip it and measure it up looking forward to see more pics cheers Rodger
  13. Mick Zilm
    26
    2
    3
    Map
    Would I need to change my drive shafts ?
  14. Rodger
    960
    385
    83
    Map
    It's listed as a 4 speed so logically it has had a g/box change. The listing implies but does not state for sure that 60s with 5 speed boxes weren't imported into Oz until '85.
    Drive shafts? I think you could swap the axles. We'd need to check the codes to ensure that they are the same ratio and you'd need to check the 60 axle is okay - drop oil, check colour and look for metal bits.
    As for shift sticks they should fit in the existing holes but you may need to move the g/box mount(?). What number of splines on your existing box? I think the spline on the 5 speed is 10 spline.
    regards
    Rodger
  15. Mick Zilm
    26
    2
    3
    Map
    Mines 10 spline my plan would be to use the 60s box ,tail shafts ,diffs and the tunnel ( I think that's what they call the cover where holes are located for shifters ) I will check the oil and let you know . The 60 has no wheels so might be a couple of days before I get it home I am going to get the carton today but won't drain oil until after I tow it home will let you know once I have it
    Rodger likes this.
  16. Mick Zilm
    26
    2
    3
    Map
    I picked up the 60 yesterday started to strip it should have rear end off tomorrow . Where would I find codes or info on the diffs for the ratio ?
  17. Rodger
    960
    385
    83
    Map
    Hi Mick,
    Re axle codes - extract from Cruiserfaq below:
    Axle Codes
    Axle codes are never located on the axle housings themselves. In trucks manufacturered after 1976, the axle codes are located on the build plate which can be found inside the engine compartment. The pinion (and sometimes the ring gear have the tooth counts (from which the ratio can be calculated) stamped into them.
    For the 80 Series, the number of teeth on the ring and pinion were increased. While the earlier heavy-duty 4.11:1 gears had 37 teeth on the ring gear and 9 on the pinion, from 1990 on, the gears were actually 4.10:1 with 41 ring gear teeth and 10 pinion teeth.
    Code Example:
    K 08 2
    9.5" ring gear 4.11 ring/pinion ratio 2 spider gears
    First digit: ring gear size
    G 8" Hilux and Light-duty LC
    K 9.5" Regular LC
    Second, third digits: ring/pinion gear ratio
    (These numbers apply to ALL Toyota vehicles--known Land Cruiser ratios are indicated)
    Code Ratio Teeth Heavy Duty Cruiser Light Duty Cruiser/Hilux 8" Reverse Cut
    R P Toyota Aftermarket Toyota Aftermarket Toyota Aftermarket
    01 3.30
    02 3.36
    03 3.545
    04 3.556
    05 3.70 37 10 X X
    06 3.889
    07 3.90 X
    08 4.111 37 9 X X X
    09 4.222
    10 4.375
    11 4.444
    12 4.625
    13 4.79
    14 4.875 39 8 X X X X
    15 5.125
    16 5.286 X X X
    17 5.60
    18 5.714
    19 5.833
    20 6.167
    21 6.667
    22 6.78
    23 6.833
    24 7.64
    25 4.556 41 9 X X X X X
    26 5.571
    27 3.364
    28 4.30 43 10 X X
    29 4.10 41 10 X X
    30 3.727 41 11 X X
    31 3.909
    32 6.591 or 5.583
    33 7.503 or 5.583
    34 6.781 or 4.786
    35 7.636 or 5.60
    36 4.778
    37 3.583
    38 3.417
    Fourth digit: number of spider gears, limited slip/locker
    Code Spiders Differential
    2 2 Open
    3 2 Limited Slip
    4 4 Locking Diff
    5 4 Limited Slip
    Hope that helps
    Rodger
Share This Page
    Dismiss Notice
