80 Series Mechanic South London
Craigus76
I am in south_africa
Aug 15, 2016
21
2
3
Morden, South London
Hi Guys
Have had a problem with my centre diff lock for 2 months now and had tons of assistance from members on this club with a lot of things I could try, which I really appreciate. Alas I haven't been able to fix myself and now the car has been standing for 2 months and I have to get it sorted asap. Please can someone recommend a garage / mechanic in the London area? I am in Morden but if I have to send a bit out then so be it so long as it is fixed. I cant drive it so wherever it has to go its going o the back of a flatbed :(
My last resort will be Currys Toyota who did my mot and service when I first got the car - they seem ok but don't think much 80 series come in there so probably mechanics not clued up.
Any recommendations would be greatly appreciated! And yes I know there is a few guys reading this going tut tut tut cause they do their own cars but I have tried all that I can up to my skill set and location of vehicle I promise!
THANKS!!
Craig
GeekOKent
I am in uk
Jul 1, 2013
2,197
633
113
London, by day.. Kent, by choice
Hi Guys
THANKS!!
Craig
Speak with @Trevor and Ed at freedom4x4 not quite south london but they are not that far out.
There are a couple of toyota specialist around here. And into kent. Noone that I could find who knows these trucks though.
  • Like
Reactions: Craigus76
Super Moderator
I am in europe
Feb 24, 2010
16,879
3,732
113
Chesterfield, Derbyshire
I would suggest that you try anything but your main dealer. Financially that would be ruinous.
Up in the air, props off, 7 bolts out of the transfer box and it's off and on the bench. It can be unlocked manually and back on in a couple of hours. That's if it can't be fixed with the wheels dangling to begin with.
Trev's your man and he has a trailer.
Craigus76
Aug 15, 2016
21
2
3
hi Chris
ok Chas has contacted me and might be able to hook up and give me a hand so will see what he says later. You referring to Trevor @ Freedom 4x4 re trailer?
thx
Pumpy
I am in england
Aug 6, 2015
523
195
63
East Northants
Mines on Trevors ramp on wed for similar issue, the actuator had seized on mine, we put a new one on but something has also gone in the tbox, difflock light comes on, stays on, but it's not actially locking the diff, it nearly exploded on the way home judging from the noise coming from it, I could take some pics on wed if it'll help!
Craigus76
Aug 15, 2016
21
2
3
Hi Pumpy
sorry to hear and i feel your pain! If you have a pic of teh transfer box off or of the propshaft down then yes. But i think i will be getting Trevor involved!
Super Moderator
I am in europe
Feb 24, 2010
16,879
3,732
113
Tranny box looks like this. The ring with the red gasket showing is where the actuator motor sits. Impossible to get to with the thing bolted on.The last pic is what it looks like under there with it unbolted. It's a very easy thing to get off.
Scott
1,029
112
63
Essex
If the front prop shaft is unbolted and removed I would expect this 80 to drive on the rear axle only. The seized in the engaged position centre difflock is locking the two output flanges of the transfer box together, but as the front transfer box output flange is no longer connected to the front axle via the prop there will be no transmission wind up. Then the 80 can be driven cautiously as you listen to the front axle, whilst turning, to listen for any nasty nosies from CVs that may have been damaged by transmission wind up.
If it drives ok, you then have a mobile 80 that can be driven to Trevor for further repairs. This is the easiest way I can see for a novice mechanic to mobilise an 80 with this fault.
Apologies if this has already been discussed, I'm late to the party on this one.
Super Moderator
I am in europe
Feb 24, 2010
16,879
3,732
113
It's what I said Scott. I agree, it's the first thing I'd try. Even if it's trailered somewhere first. The box could be stuffed to the point that it's screwed completely, or it might be just enough to allow it to drive ok to get it mobile again. The prop has to come off any way so you're not losing anything. It does mean that there'd be little prospect of further damage if driven.
AdBlock Detected
