Steve Wright
- Mar 4, 2010
Hi Folks
Before I went away on my hols, I found one of the pipes leaking under the sill (just behind the Front O/S wheel) but cannot decide which it is, it could be:
1, AHC piping
2,Water piping to the rear
3,Rear Air con piping
4, Some other piping (but cannot think what else)
But suspect its the Air-con, there is two pipes that run together, one roughly the size of brake pipes, and the other about 25mm in diameter. and the thicker one is covered in a foam insulating jacket just like you would find for pipe lagging, the liquid coming out is clear but with a oily feel, and there is not a lot of it ! (the foam has a few droplets, but not a puddle on the floor)
It's not a good place to take a picture, but also cannot attach to the post.
So does any one know which this pipe is, and any one know a very good independent garage in the N/W near Manchester ?
1, AHC piping
