- Mar 1, 2010
Yes up down or sideways play describes it. It's not like a buckled cycle wheel.
I can't see much movement on the video.
The main bearing is locked when the a/c is on and won't be turning therefore that won't be what's making the noise.
Won't the pulley still be turning on the bearing Frank? As the bearing is between the pump nose which is static and the pulley, just with the clutch plate pulled in and engaged with the pulley?The main bearing is locked when the a/c is on and won't be turning therefore that won't be what's making the noise.
Yes you're right Richard. I still think the noise must be the compressor as silence when not engaged.
I think a new compressor comes with a full system charge of oil doesn't it ? I wonder if they allow for the oil left in the system as not all comes out with the old compressor but spread around the system.
This is ok Dave except that the system loses oil over time. My fridge engineer pal blew out my system with nitrogen at first then a squirt of 134a and not a drop of oil came back out. He was certain this would be sufficient and was adamant that the oil level supplied with the compressor would be fine with any that was left in the system. Good luck finding the correct receiver/filter/drier, we had quite a job but did find one that was shorter but my pal was not put off by this. I can't remember whether it was the one he got or the eBay one I got but one fitted and one didn't.You drain the old oil from the old compressor, and measure the amount. You then drain the new compressor, and replace the same amount of oil as came from the old compressor. Preferably use new fresh oil, and not the stuff you drained from the new compressor. Depending on what else gets replaced/flushed, then the amount going back into the system gets adjusted accordingly.
