- May 26, 2014
Noticed fuel leaking from the acsd the other day. Is it always the case that the shaft is worn or could i just get away with replacing the o ring?
Ive read that some do away with it completely and it works by altering the pump timing rather than putting more fuel in. How does altering the timing help with cold starting? Increases the compression?
Sooo, if i remove the system completly will i achieve the same amount of cold start help by pulling the hand throttle out to increase fuelling?
I like all of the 80s cold start goodies, some people are building there 80 for the zombie apocalypse. Im building mine for the zombie apocalypse and the impending mini ice age!
