zfsteering
- Feb 10, 2013
My vehicle has a coded key fob with two metal contacts that have to be connected to the female part on the steering column every time on start-up.
The one coded key packed in this morning for some reason and I am now using the last spare key fob.
I would be inclined to cut this whole unit out of my ignition as it is a pain to use every time on starting.........
Is it relatively simple to snip the unit out of the wiring loom on the column and remove the box unit under the dash without loosing ignition etc. etc.?
Thanks.
Stephen
Thanks.
Stephen
