Mick W
- Mar 2, 2020
Will do cheers. I did try my VIN but it wasn't recognised. I've contacted them so hopefully will get the right part number. I could always learn Japanese while I'm on furloughIf you find a UK spec cruiser and use the vin number for that with a bit of luck you should get a different part number and the UK version of that. Maybe someone on here would be kind enough to supply a vin by pm for you to use. I wanted to change mine when I first bought the truck but have never got round to it.
You can use a translate app to scan the writing and then save it on your phone. I used one to read the Japanese labels in my 90 to see what they said. It works very well.Well I received my Amayama decal delivery today. One was for the recent timing belt change and the other was a replacement for the drivers door diff lock process. Not sure I'll be able to use that one for guidance when I'm stuck
Cheers BertTaking it directly from the screen, it translates as:
I expect it to work better from the priginal label
Cheers @BertTaking it directly from the screen, it translates as:
