Hi All, im based in UK/Ireland and my LC200 has developed blue smoke on acceleration. I recently cleaned Inlet manifold of gunk and blanked EGR. There was small trace of oil in inter cooler / pipes and inlet that i would suspect as normal. After doing research I see a couple good videos from Australia explaining about the scavenger pump failing and causing oil to enter turbos and give symptoms of a failed turbo. Im just looking to see if any other people have had turbo issues. Also I see videos f guys complaining of PCM issues and causing oil to enter one of the turbos.
Any help or advice much apprecited
