- Jun 30, 2011
My LC is my daily driver, and to be honest, as we are saving for a house build, I don't have the money to spend on some of the desirable gear thats available out there. So I decided to see what I could do, on a budget, that would suit our needs for camping trips in France/Spain/Italy that have quickly become annual holidays.
First job: Awning - somewhat inspired by one I saw online.
Materials: 2x2m Heavy Duty Tarp - Actually a tent floor from a broken tent
Length of 110mm black drain pipe & stop ends
2 tent poles
2 x 4m lengths of 20mm pvc overflow pipe & 4 x 90' elbows
Pop rivets & mudflap washers
M6x100 bolts, nuts & washers x2
Total Spend - €60
Started by making the awning itself - Riveted the 20mm pipe onto the ends of the material
The sides are made of the 20mm pipe with the 90' bends on them that get attached for putting it up. For now I'm holding it to the roof rails using strong bungees, as i want it to be quick to put up and take down. Velcro straps hold the sides of the awning to the pipe. Only thing i need to make for it is a pair of small weights for the guy ropes (substituted by oil cans in the pic!)
Rolls up nice and tight...
Which leads to the cassette case for it...
Cut to size and test fitted....
I had to flare one end of the pipe by heating it with a gas torch so I could push the end cap onto it, otherwise it would need a big ugly socket connector.
Bolted through the existing roof bar clamp using the m6x100 bolts with mudflap washers shaped to fit the inside of the pipe. Lock nut on the end so it can't loosen. Added a couple of 7mm cable ties for support - probably unnecessary but want it to be able for motorway speeds
Screw on acces ends fitted
Slide in the awning...
A €5 fleabay finishing touch...
Finished...
Had thought about making a retractable version, but this set up allows me to put the awning on either side of the truck, or even at the back if i want. Happy with how it turned out. Now on to the rest of the list!!!
2 tent poles
Total Spend - €60
Finished...
