Battery not charging LJ70
Si LJ70
great_britain
It's me again!
The battery isn't charging. I am going to check the alternator with a multi- meter at the weekend. I assume it's the culprit.
But thought I would ask if there is any know causes/ issues? For example corroded earthing, wires being worn through etc.
Simon
Is the red light coming on, telling you no charge, or is your battery just going flat ?
Check the plug and wiring at the back of alternator and make sure wiring intact and all connections clean, a common fault with charging issues.
