- Feb 24, 2010
Folks,
As some of you know I dabble in quadcopters etc. On my latest build I need to drill mid-way into one of the arms (25mm round carbon fibre tube) to allow for some cables to exit and was wondering where would be best to drill? Top, side, bottom, off-centred?
The arms are 25mm carbon fibre, prop and motor at one end pulling up (max thrust is about 1.1KGs I believe) and load at the other end which will be 1/6th of 2-3KGs.
Personally I don't think that there will be a problem with small loads like this if I drill a 10mm hole into the side of the tube (I may be wrong?) But was curious about where the best place would be? I think the bottom as it is a tensile load around the hole then.
cheers,
CP
cheers,
CP
