Bit of tech knowledge needed
I think you will find it means she can't control it with her phone .
It's what me and you would call a normal heater JR because it can't connect to the internet .
They are good heaters JM. Shayne has it spot on and no it shouldn't interfere with your wifi signal. Have a look at the DeLonghi Dragon too. We have a 4m x 5.5m 70mm thick Cabin in our garden that gets heated very nicely with one of those. Mind you I did put 125mm of Celotex on the roof and 50mm under the floor.
Thanks both, It's timber framed 5 meters x 2 meters lined with a breathable membrane inside & out including the floor & yes it's fully insulated with Celotex
That should more than cope with that area (dependent on height) down to -5 I would expect.
We have 3 2000watt oil fired heaters we done use any more due to the heating working now. If interested
