Got to open the tent up and have a play today
There's surprisingly little information about airtop or at least I didn't find much so I thought I'd post some pictures and compare it to the wind up maggiolina I had before.
The Airtop has a back door. In theory that means you shouldn't have to climb over your partner to get in and out as happens with the side entrance.
The side doors (and the rear door) have the same fly mesh as the wind up model but it doesn't have the zip panel in the top of the door for ventilation which is a shame because that's a really good feature on a hot day. The bigger end panel windows of the airtop are supposed to make up for that but I think they should have given it the extra door panels as well.
very cosy inside. There are small cut outs in the matress for the roof supports to fold in to so technicaly you lose a little width but in practice unless you like to sleep with your head against the side of the tent I don't think it'll matter and the benefit is that you get the full length of the tent because there's no sissor jacks at the ends like the wind up model.
not sure if i'll use the back or side entrance yet
back entrance has a big window in it for ventilation. Something I don't think the literature shows for either style of these tents is the little flap of material on the bottom of the doors that folds inside and makes a draft excluder. From the outside it looks like you might get a draft under the door but the flap fixes that so it's well sealed.
to close just pull the front down, give the material in the front a bit of help to fold inwards as it goes and pop the straps in to the first click
TJ at BOAB was convinced it would be hard work to pull the front of the tent down because of being reaching across and up and the struts being quite strong so I had all sorts of ideas for ways to deal with that but as it turns out I can just grab it and pull it down without trying very hard at all
then pull the back down and again put the strap on the first click
then go round and poke anything sticking out so it's not and then do the straps up tight and you're ready to roll.
On the previous wind up one there was a bit more going round poking bits back in but it was still quite quick to put away. The elastics in this one do most of the work so there's hardly any tucking in to be done at all making it much quicker and this was only the second time I'd closed it
