1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Bonnet flutter.
hopeless wanderer Aug 9, 2017
  1. Gary820
    Gary820 Well-Known Member I am in great_britain
    2,602
    765
    113
    Garage:
    Map
    Didn't notice any movement earlier even a bit past 70mph :whistle: private road of course
    hopeless wanderer likes this.
  2. hopeless wanderer
    hopeless wanderer Well-Known Member I am in england
    518
    283
    63
    Map
    Some of those private roads are great, they have signs and lights and roadworks and everything .
    clivehorridge, Gary820 and Chas like this.
  3. clivehorridge
    12,571
    2,741
    113
    Garage:
    Map
    ... and police even... :shifty:
  4. Dave 2000
    Dave 2000 Well-Known Member Supporter I am in spain
    2,252
    484
    83
    Map
    Mine used to do it, lifting the stops had the bonnet line above the wing.
    There is a solution.
    First wind the stops right down, there is a centre spar under the lock, file the holes into slots and pull the mechanism down quite hard and tighten the IIRC 5 bolts, 3 + 2 in the spar?
    Now close the bonnet to confirm it sits lower than the wings, open and adust the outer stops.
    Ultimately your trying to put a 'bow' in the bonnet which will not happen as the leading edge is rolled, you do need to drop the bonnet to get it to engage in the lock, but no need to slam.
    Dave
  5. hopeless wanderer
    518
    283
    63
    Map
    Cheers Dave.
    I've taken the spar out and slapped an intercooler in there, but given your advice im going to replace the pressed spar with a bent bar or strap that clears the intercooler and puts the crossmember the lock is mounted to under tension.
    Dave 2000 and clivehorridge like this.
  6. Dave 2000
    2,252
    484
    83
    Map
    :thumbup:
    Dave
Share This Page
