- Jul 24, 2015
I think this was answered above but because it's the braking system I want to be really sure I am doing the correct thing.
As you can see below one side of the reservoir has emptied and the system has drained. Can I just refill the reservoir with fluid then bleed as normal with a vacuum bleeder (topping it up as I go)? Or do I need to bleed the master cylinder in some special way?
There is no abs, and it's a vacuum booster, if that makes any difference.
Sorry to ask a question thats already been answered but id rather be safe than sorry.
