goodoldboy
- Apr 30, 2010
So Milner vs OEM from roughtrax.are the Toyota ones twice as good?
thanks lads the milners it is then.the position is really exposed but they've lasted 19 years.I did read somewhere about a mod to protect em using construction foam?Milners here and perfectly happy since I fitted them 12 months ago
I don't have any mudflaps on at the mo - the standard ones came off with the side steps & the home made rubber ones got ripped off reversing...so ill look at some sort of cover.I used to have a trayback hilux & through about building some sort of fender/ boxed in wheelarch as even with mudflaps the whole chassis was minging most of the time...I used lots of rtv in the rear of the fittings to try and get it waterproof, no fun when the bulbs corrode into the holder. All the exposed metalwork on the back of the lights I painted as well.
I had the same issue, worked out the correct wiring and Milners asked if I could send them a photo so they could correct that. This was about 3 years ago.
