Rob Cowell
- Nov 15, 2011
Much excitement today as my tow bracket came lose while retruning from my feed merchant with a couple of tons of feed. Would have been even more exciting yesterday when I had 50 lambs over two mountain passes on the way to market.
I think a captive nut has come lose and allowed the bracket some movement which has lead to the front plate cracking as per piccy below.
The captive nut is attached to the bolt you can see on the left of this pic. It's now completely out. So I just have a hole in the crossmember.
So, captive nut question in the context of something important like a tow bracket. I reckon I can just get a free nut in there by hand / spanner. There are fairly conveniently large holes as part of the cross member pressing that I think will allow this. As long as I can get the torque is this a reasonable solution? I really don't want to cut the crossmember to get a welder in there.
Would seam welding the plate to the crossmember be a bad idea?
Any clever captive nut solutions I haven't seem?
Ta
Ta
