AboutAfrica
- May 19, 2019
Anybody know what the correct/standard castor is for the 105?
I recently put in a 3.5deg castor correction kit from dobinsons, on the wheel alignment machine it now gives reading of +2, which puts it in the green (acceptable) spectrum. Before the castor correction I was -05.20
I just want to know how close am I to standard spec?
After the castor correction I now have slight rubbing of the steering rod on the radius arms at flex, but will fix that with a grinder over the weekend,
thanks
thanks
