CB radio poor range
Bat21 May 15, 2017
  1. Gary820
    Gary820 Well-Known Member I am in great_britain
    2,718
    891
    113
    Garage:
    Map
    I've got the antenna mounted to the top of the A bar, get 1.5 to 2 miles range. No issues with transmitting or receiving.
    clivehorridge likes this.
  2. StarCruiser
    8,432
    2,875
    113
    Garage:
    Map
    A bigger antenna often aids reception and transmission as well as getting it as high as possible. Both rather tricky on a vehicle. Long antennas get in the way and whip about and the only way to gain height is to drive to a high spot.
    Many in Sussex 4x4 Response have gained amateur radio licences which allow for greater power on the 2m band. 10 watts on the foundation licence, then 50 on the intermediate but to get any real distance you still need height and a good antenna. Vehicle mounted I'd say 5 miles is practical on 10 watts from a moving vehicle with landscape and buildings around.
  3. clivehorridge
    13,152
    3,165
    113
    Garage:
    Map
    How long is yours Gary? :doh:The bloody antenna I mean :angry-nono:
  4. Crispin
    Crispin Administrator Staff Member Supporter Guru I am in great_britain
    5,836
    421
    83
    Map
    Sounds like you need a "108 whip" :D those were the things to have in the 80s and 90s!
    Sounds like you might be down on power with that. Tried a cheap power meter?
    Could it be that yours is slightly off frequency and the fact that you're actually getting anywhere at all is just harmonics?
  5. Gary820
    2,718
    891
    113
    Garage:
    Map
    Not too long, i think it's a 48" (80 not here to check)
    Can see it in the pic.
    I don't use a Springer antenna and this one doesn't whip around all over, it barely moves under normal circumstances but flexes well when branches etc catch it.
  6. clivehorridge
    13,152
    3,165
    113
    Garage:
    Map
    Mmmmm, similar to mine.... I don't have the springy thingy either.
  7. pyemaster
    pyemaster Member
    109
    91
    28
    Garage:
    Map
    I run a T1000 off a bumper-mounted 4ft top-loaded Firestik, and get a solid range when mobile, up to around 8km. The conditions have to be right (not surrounded by buildings, etc), but so long as one of us is in the clear and not sunken in a valley, comms is pretty good. I made sure my SWR was tuned in a big, flat, empty area, on UK 1, 19, 40 and EU 1, 19, and 40, all below 1.5.
    Owen
    EDIT - I should add some of the breakers talk from big-antenna base stations, which certainly helps them!
  8. Bat21
    Bat21 Well-Known Member Supporter I am in morocco
    1,803
    75
    48
    Map
    Eureka.... 'I've found it'
    All the previous installations were lacking a decent 'ground plane'
    I have fabricated a solution which now gives me almost a 4 mile range which is a lot better than the <1 mile one for the last 10 years.
    A 200mm x 600mm plate fixed to the top of the front ARB with the Sirio antenna fixed in the centre.
    grantw and StarCruiser like this.
  9. StarCruiser
    8,432
    2,875
    113
    Garage:
    Map
    Well done Bat. :clap::dance:
    Pleased you've got it sorted.
  10. clivehorridge
    13,152
    3,165
    113
    Garage:
    Map
    I think that begs a photo Bat, for positioning etc., if there's any chance, sounds good though!:thumbup:
  11. Bat21
    1,803
    75
    48
    Map
    Here you go Clive, function clearly takes precedence over form here..... but it has made a huge difference to the range.
  12. clivehorridge
    13,152
    3,165
    113
    Garage:
    Map
    Cheers Bat, not knowing what I'm on about, in a technical sense, it looks like you've made a "connection" between ground planes by adding one to the antenna, and thus transferring ground plane to the bonnet.
    That may be a load of crap, but it kinda has some logic to it.
    Thanks again!
    PS how d'ya get to the bonnet safety release catch now?
  13. Bat21
    1,803
    75
    48
    Map
    The plate is essentially the 'Ground Plane'. I kept it as close to the bonnet as possible to allow the bonnet to act as a plane too.
    The plate has a small earth wire running from it to the chassis too as I didn't want to grind off the powder coating from the ARB.
    When the antenna was mounted just on the ARB spot light brackets there was next to nothing to 'bounce' the signal up and out, hence the previous poor range.
  14. clivehorridge
    13,152
    3,165
    113
    Garage:
    Map
    Makes sense, how do you get to the bonnet release now, it looks very tight in there now...?
  15. Bat21
    1,803
    75
    48
    Map
    Bonnet lifting is simple, there is enough room to put my hand under the plate and release the catch as normal.
  16. clivehorridge
    13,152
    3,165
    113
    Garage:
    Map
    Aha, that's OK then, it's not so evident from the photos.
    Maybe I need a trip to the piece of steel 200 x 600 shop...
    mmmm, they do some multi-drilled plate in various sizes in the local B&Q equivalent here, I don't suppose "colander" type holes would spoil ground plane, would they?
  17. Bat21
    1,803
    75
    48
    Map
    It needs to be solid Clive. It is the solid plate that is bouncing the signal up and out..... if it was full of holes I suspect it would be less effective.
  18. clivehorridge
    13,152
    3,165
    113
    Garage:
    Map
    I take your point...
    They're only little 3/16" holes, mind...
  19. Bat21
    1,803
    75
    48
    Map
    That might mean you will lose 3/16th's of your transmission signal :blush::smiley:
  20. Towpack
    Towpack Well-Known Member I am in england
    2,751
    609
    113
    Garage:
    Map
    I don't think a few holes would make much difference. A ground plane can be made from a few radially spaced rods (ideally 1/4 wave length long). Siting whip antennas on a vehicle is very much trial and error as there are so many influencing factors.
Share This Page
    Dismiss Notice
