Joe_W
- Jan 22, 2019
I have found what could potentially be the issue. Its on the passenger side JB the one with the fuse panel on in the footwell. There seems to be a few connectors that are corroded. I have had a look at the wiring diagram and it is connectors '2P'. I need to study/learn how to read the wiring diagram to check where each connection goes to to confirm it is this causing the problems. Typically the problem stopped today. Definitely seems to last a few days after some wet weather the fix itself.
