Changing power steering fluid.
rekab69
I am in uk
Apr 24, 2018
51
29
18
Hi Guys,
Noticed my power steering groans a little louder than I remember.. Checked the fluid level which is fine but it does seem to be a yucky brown colour..
Thought I'd change it..
How is best to remove the old fluid, I have an oil suction kit so plan on using that unless there is another way...
Also after a quick search on the web it's seem only Genuine Toyota fluid is the best to put in.. ??
Also anyone know how much I will require..?
Many thanks in advance,
db.
Shayne
Feb 2, 2013
12,709
4,560
113
South Wales UK
On my 90 i just unbolted the pipes at the rack a let it drain , I was surprised how little fluid it uses so i unbolted the pipes again letting the new fluid drain washing out whatever was left of the old knowing i had enough left in the bottle to refill . Can't imagine your truck being much different .
Super Moderator
I am in europe
Feb 24, 2010
16,886
3,741
113
Chesterfield, Derbyshire
As Toyota don't actually make any of their own oils and fluids, I'd suspect that anything off the shelf that at least has the same standard (DOT4, 5 etc) will be fine. These are effectively lorry engines and don't need to run on unicorn tears. I stopped putting Toyota diesel in a long time ago. I know Frank still only uses genuine Toyota air in his tyres though. :icon-biggrin:
  • Like
Reactions: Bmonck and rekab69
Towpack
I am in england
Oct 4, 2011
3,577
1,179
113
UK
I changed mine on the 80 by disconnecting the return pipe to the reservoir and diverting into a plastic container. Then, with the engine started, kept the reservoir filled with new fluid as the pump circulated it until it came out of the return pipe clean. It pumps round at a fair old rate and only takes maybe 20-30 secs to purge the whole system.
  • Like
flint
1,222
747
113
Not sure if it's the same on LCs, but when changing fluid it helps to have the front wheels off the ground and turn from lock to lock with the engine running to purge any air. ATF Dexron 3 needed I think.
  • Like
Reactions: rekab69
Super Moderator
I am in europe
Feb 24, 2010
16,886
3,741
113
Sorry - apols. I didn't mean that you should put brake fluid in the PS. I can see that looked like what I was saying. DOH. I just couldn't recall the codes / types etc for PS fluid. it's something like Dextron II or III isn't it?
I just meant that it's really nothing special. Just like antifreeze. I don't mean put anti freeze in your PS ...
Oh dear.
  • Like
Reactions: rekab69
uHu
I am in norway
Mar 7, 2010
2,026
392
83
Oslo, Norway
Dexron III is the fluid you need. "Power Steering Fluid" is not good. Use only normal ATF. It seems that it has a hard life in the power steering tho', so a synthetic Dexron III ATF is good. Is seems to hold up better without getting that burnt smell.
To change the fluid, just take off the return hose and hold it into a small bucket. Then turn the wheels from right to left and back, while keeping the reservoir filled up, until its all changed out.
  • Like
Reactions: rekab69
rekab69
I am in uk
Apr 24, 2018
51
29
18
Thanks for all your replies guys, so if I'm reading this correctly.. Any other manufactures red anti freeze , keep the front wheels off the ground for ever so i don't actually need power assisted steering.. :)
  • Like
Reactions: chapel gate
rekab69
I am in uk
Apr 24, 2018
51
29
18
Wheels back down on the ground now... would old oil or it may even be the wrong oil in there account for a groaning, moaning sound when turning even at speed..?
Jake the Peg
I am in scotland
Aug 17, 2018
264
179
43
Highlands
Did you turn lock to lock a few times after refilling the reservoir to bleed out the air from the steering rack and hoses, then check the level with the engine running?
Any pics of your Quattro? I have been doing a lot of work on a friends SWB sport, it was just under 500hp on the dyno, and is quite fun on the road!
  • Like
rekab69
I am in uk
Apr 24, 2018
51
29
18
  • Like
Reactions: Jake the Peg
rekab69
I am in uk
Apr 24, 2018
51
29
18
500hp...?? That's over double mine makes... :) Owned it over 20 years, never had an accident... Son just passed his test and reverses his Corsa into the side of it.....!!!
AdBlock Detected
