- Oct 14, 2013
Mine did that when i changed the filter. stopped dripping after a bit. take a piccy of the o ring replacement please Clive (with measurements) so i can find one myself, taIt wasn’t leaking at all Dervis, until I loosened the little bleed tap in the center of it, then found I couldn’t stop diesel from coming out of the tap’s tube, when I re-tightened it.
There’s no leak from the plastic assembly, or where it screws to the filter can.
If you unscrew the tap right out, it has an O ring on it that looks permanently “depressed” on the face where it contacts the hole supplying diesel from the filter in the plastic assy, and I don’t have a replacement O ring the right size.
Not to worry, its not leaking with my bodge-job and I’ll get it to service next week for them to sort out.
I’d replace the whole plastic assy if needs be, and if there’s any change from selling a kidney.
Otherwise, it might cost me the price of an O ring.
