MisterCruiser
- May 28, 2014
I've had a clunk sound when changing into 2nd gear from 1st for a few years now on my cruiser, it never got worse really, but I was often curious to know whats causing it. I don't think it does it or at least not to the same extent when changing down from 3rd. All other gears are fine, 2nd drives fine too, it's just this cluck or thud when changing into 2nd, it's not a grinding sound or anything like that, I don't think it's the gear itself in the gearbox, probably more like a bushing or linkage issue but you'd imagine more than 1 gear would be affected. It's hard to get a smooth gear change, as I'm letting the clutch out in 2nd the thud occurs.
I also have a loud clunk sound sometimes, seems to be louder now when occurs, when I first start the cruiser and go to move off and turn at the same time slowly. Where I usually park is just around the corner of my house, so when I go to reverse around the corner slowly I hear this loud clunk. It usually only does it once, if I start to drive forward and turn and try reverse around again, I can't get it to do it again. It's as if moving after been left overnight causes something to settle and then clunk when moving off the next day. I never hear this clunk during a trip or after the initial time it does it first, if I was stopped later that same day and went to move off again it doesn't do it. It's fairly loud as in a mate commented on the loudness the other day when he was walking towards my cruiser as I started to reverse around the corner. I think it's gotten louder recently, sort of like a loud click sound.
Could it be a CV joint, but it doesn't click any other time and when it does it's a single loud click, not a series of clicks like a CV joint, Iv'e no play in the wheel either, bushings / ball-joints seem ok, anti-roll bar bushings are all new on the rear and fronts seem ok too.
I don't know if the 2 sounds / issues are related but I'm interested to hear thoughts. I can live with these issues, have done for few years now but the Click noise from stationary is starting to get louder.
