BobMurphy
- Mar 1, 2010
Andrew Prince said:Are you sure that your description of the flow on the KZ-TE is correct? (I don't know the answer but it would be worth confirming while theorising over the problem and possible solutions)
Hmmmmm. No, I don't know for certain that my diagrams are correct, but:
1. The water Pump is a centrifugal pump that turns clockwise from the front. The vanes propel the coolant towards their outer tips, creating a low pressure area in the centre (i.e. suction).
The 'snail shell' design of the pump housing means that the pressurised coolant only has one exit - to the N/S of the block.
2. The question is - when the thermostat opens, which way does the coolant flow ??
Towards the front of the block, just a few inches away, is the suction side of the water pump and the connecting gallery looks quite large. Above it is a large hole allowing the coolant to pass between the block and the head.
I can't see the hot water flooding out of the lower radiator hose and the cooled water dropping down into the head and block without there being some restriction to the flow between the last link to the cylinder head and the suction side of the pump. Maybe there is something in the pump housing that I'm not seeing that causes this to happen.
The proof would be to remove the thermostat and see whether the bottom radiator hose gets hotter than the top hose.
If this was to happen it would still look wrong to me as the coldest part of the motor (bottom of the block) would still be controlling the coolant flow to the hottest part - the head.
When I bought my car the paint had been blistered off the bonnet (I haven't fixed that yet) It just proves that heat rises.
Normally, hot coolant is fed to the top of a radiator as it will stay up there, being less-dense than colder fluid, meaning that it decends through the matrix in a controlled manner, being cooled as it goes. If hot coolant was put in at the bottom it would try to rise to the top and a thermo-syphon would be set up in the radiator, meaning the hot stuff would reach the top and go back into the motor before it had cooled properly.
I'd love to be proved wrong as having the thermostat in the cold water flow makes no sense to me, so maybe it does go out the lower hose after all
Bob.
