Crankshaft pulley clearance
WC57
australia
Hi, I am a bit concerned about my harmonic balancer or crankshaft pulley clearance. I have heard of the rubber deteriorating in them allowing them to move and possible rub a hole in the front cover. Here is a pic of mine, how does it look to you guys?
GrahamR
Needs the tarnish cleaning up after months sat on the drive but here are a couple of pics of mine. I'm not sure what the symptoms of wear would be or what to look for... Never knew this was a wear item!
Trevor
Getting through alternator belts faster than normal can be a symptom.
WC57
australia
Thanks guys, looks like mine has the same clearance. I did try a pry bar and block of wood but the balancer seems solid. I have a problem with alternator belt squeal. I have fitted new belts and adjusted them as per normal but it is still there under acceleration. Don't want to go too tight. Maybe I should have a closer look at the alternator pulley?
Shayne
New belts on my 80 were an ongoing headache of squealing until pissed off with it i tightened them too much aiming to stretch them , while squealing , for a few miles before setting them as i thought they should be again . Been fine ever since .
Not for the faint hearted but i wonder if you could feel balancer wobble if you held a screwdriver to the side of the pulley while it spun ?
4 Paw Drive
scotland
Not wanting to high jack this thread, but i'm in the process of replacing the timing belt on a similar model, 2001 4.2L
The old belt didn't have a travel direction on it, but the new one does. Can anyone advise on the direction of rotation of the engine.
Does the cam pulley rotate clock wise or anti -clock when viewed from the front of the vehicle?
4 Paw Drive
J
jibberjabber
4 Paw Drive
Just out of intrest, is you new belt a genuine Toyota timing belt? When I changed mine there was no direction of travel on the new belt or the old belt.
The crankshaft pulley rotates clockwise when viewed from the front.
4 Paw Drive
scotland
The new one is from Milner 4 x 4, the old one was a Toyota.
Thanks for the reply.
4 P D
J
jibberjabber
I have had very, very bad experience with aftermarket timing belts, I would strongly advise you to fit genuine belt 1356819176.
Also, idler 1350517020, washer 9020112073, shaft/bolt 1355617010, tensioner 1354017011.
And also just incase you drop/misplace, bolt 9010906046 times 2, washer 9021008901 times 2, and bolt 9151180620 times 1.
I don't cut corners when it comes to things like timing belts, the results can be catastrophic.
This is my best advice,
Good Luck
