Howmanygoes
- Jan 14, 2019
Afternoon all
after seeing a few of you with the monitoring last year I decided when I rewired I would go the same way. So I now have a victron bmv712.
i also run a ctek 250sa with both solar and starter battery supply
iam having an issue sorting out the location for all the -ve connections
ctek show a chassis -ve to the leisure battery and this is how I have always had it, with no issue.
The bmv shunt wiring diagram only shows a leisure battery connection to the battery side though with all the system/charger connections the other side (see images). The diagram also shows the starter battery connected to the system side of the shunt. So should may chassis ground go here too?
crude wiring diagram attached and both product drawings
