- Apr 21, 2022
Hello fellow 80'ers,
A couple years ago i was finding my batteries were flattening down overnight, and decided to replace the alternator.
That cured the problem, and obviously had a bad diode or rectifier unit etc.
However, ever since that, every time i start up - all the dash lights remain on for anything up to a minute unless I give the throttle a quick tap.
Interestingly, if I don't tap the throttle, I've noticed there's a relay clunk somewhere in the engine bay that coincides with the lights finally going out.
I suspect it's the glow plug heater system timer - but the lights do this annoying thing whether hot or cold when starting the engine.
I swapped the alternator for a non-original unit but a new, not remanufactured or refurbished one.
Oval plug, and on a 1993/94 12 valve 1-HDT engine.
Never had a flat battery issue since, just this annoying dash lights thing.
Anyone else had a similar thing happen or know what it could be?
