- Mar 11, 2014
After much umming and aahing I decided to lash out on a dehumidifier to use in the house (old, stone built) as the windows (d/g) were getting a bit of condensation on a cold morning. It did the trick, sucked out a couple of litres from the air and the rooms involved felt better to be in. I thought it would be interesting to put it in the 80 overnight, no noticeable leaks but a bit of screen misting some mornings. After about 12 hours, over a litre and a half had collected in the dehumidifier tank which I wasn't expecting. I used a thin extension past a door seal and made sure all windows and vents etc. were shut, so most of that must have been from the interior. I got a dessicant machine (Maeco) so not too much leccy used and will work in lower temperatures than a compressor type, seems to work well.
