Tractionman
- Oct 11, 2013
Any recommendations for rear drop links. Mr T are shut, Roughtrax are shut, Milners appear to be open(on line, anyway) + various others/brands on line available. Thanks.
Update on this. Was all set to order from Milners, but laying under cruiser got in way, so as I'm cleaning off rust, rust proofing, painting and undersealing, working back to the front, a rubber body mount/ bumper didn't look right, gave it a poke and it fell off. This is a circular piece of rubber approx 2" across and 2" high bonded to a circular 'washer', and bolted to underside of body by a bolt through the centre. Can't find one of these anywhere, maybe because I have wrong name. Then a main bump stop fell off, same reason, unbonded by rust.
Moving on, I find both rear shocks upper sleeves are badly perforated, although not leaking. So am getting quite a list so far, which I was hoping to source all from Milners, who are open on line. Unfortunately, they don't seem to do rubber body mount/ bumper or main bump stops. With the main one I may be able to re bond as metal plate still on there has cleaned up and main bump stop is sound.
Not from what shes told me!!Reading that, it could influence my Mrs. as well !!
Perhaps you've 'droped' it someware.And I wish I could find the bugger I misplaced !
StinkyYeah, I'm always dropping one ?
But I like you !Ooh, you are awful !
Just shows how thoughtful I am for not keeping you waiting long.I was waiting for that !
