Howmanygoes
- Jan 14, 2019
I did look back at the original numbers and noticed the difference, made the assumption I had a load on last time which would have made them comparable. Will test again and report back.Do it while testing voltage across the battery and see if it causes any repeatable change in voltage. It’s not giving the same thing est results you posted earlier in the thread which seems to indicate there may be something going on with the alternator or a loose or corroded connection somewhere.
