Electric window gremlins
colin_h
ireland
Hi all. My colorado has a strange window issue
Drivers side
Can put all windows down but can only put up drivers side and both rear windows up. Passenger won't go up
Passenger front and rear windows
Can put windows up and down at each switch on the respective doors.
When child lock is on I can still put all windows down at each switch but this can also cause the passenger front window to go up.
I replaced the drivers window switches and still the same. Anyone ever had this issue? Thanks
My rear left window didn't work for ten years either at the door or the master control; I bit the bullet last year and bought a £20 cheap Chinese knock-off master switch unit which fixed it. Years ago I had trouble with the central locking and that was due to broken wires in the loom between the driver's door and the body, they just needed reconnecting - probably worth checking the loom here first as breaks are really common before replacing components.
Drivers side
What did you replace the drivers door switch panel with, a 2nd hand one or an aftermarket one or a genuine one?
