Eventually started with some jobs
Jake the Peg Jan 29, 2019
  1. Jake the Peg
    Jake the Peg Well-Known Member I am in scotland
    206
    139
    43
    Map
    So not many pictures yet but I’ll start with these 2! Having farted about trying hoping for some black magic to stop the knock knock knocking in the engine, I think it finally came!
    Replaced the big ends, found #3 was starting to crater but on rebuild it still sounded the same. I used some fuel additive neat to the filter and over dosed the fuel in the tank, and after a few minutes running it now as it warms up the wee man with the hammer has a break and it’s fairly quiet. I’ll have the injectors serviced and new nozzles fitted. There is a rumble from the gearbox / clutch but I’m not really worried about that, it has had a clutch in the past, and I’ll change the gearbox oil before it returns to the road
    Parts are arriving now, but time in the workshop is limited as to when the children are in nursery and I’m not taking it home to work outside!
    Rear axle: New pads and discs, new handbrake shoes springs and modified dog bones, cranks stripped cleaned and greased up, axle bushes, anti-roll bar bushes
    Front axle: changing out the axle case, all bearing and seals and gaskets will be done. New bushes for the radius arms, anti-roll bar, it has very recent pads and discs
    Body and Chassis: rear section / boot floor has been cleaned up, flaky paint and sealer removed, rust removed and treated and coated with stone chip and tetraseal
    Rear body mounted spare wheel carrier refitted to cover the holes
    New drivers front window regulatorfitted, still as slow as a week in jail!
    Interior: carpets removed and power washed and refitted, apprentice quality wiring repairs & alarm install removed ( why do people love to strip, twist and insulating tape anything they can ?) Refit interior . Front seats are still to be changed out
    Engine : Big end bearings changed, valve clearances reset and an oil flush done, timing belt, water pump, radiator and aux belts to be changed. Alternator to strip, clean inspect, hopefully a new regulator will sort the dash Christmas tree
    2853A67C-5262-4B65-A18A-DA447DA77DFF.jpeg 58ADE528-F28C-4F05-AED2-730EFA8D30A1.jpeg 0E49B14C-45CF-410A-803A-568E7AEEDA7C.jpeg
  2. froggy Steve
    froggy Steve Well-Known Member Supporter I am in europe
    2,670
    554
    113
    Map
    Good job! Have you gone for longer dog bones? I had longer ones in mine but then had new shoes fitted and it's a bugger to get it right! ......according to the mech....who I am losing faith in!
  3. Chris
    Chris Super Moderator Supporter I am in europe
    16,132
    3,221
    113
    Garage:
    Map
    Fantastic. You know, if you get a half decent starter and do the axles BEBs, bearings, brakes and so on - coming in at a total of say £5 £6k then you're really driving around in a pretty awesome motor. Sure, the bumpers might have a ding or two there may be some scratches and bits of rust about the place but at the end of it all, you've a continent crushing beastie. Fantastic effort in getting this one back to some of it's former glory.
    Jake the Peg and clivehorridge like this.
  4. Jake the Peg
    206
    139
    43
    Map
    Steve I’m waiting on the discs arriving, and the short crank cables, and after that
    I’ll let you know. I just cut a piece of steel and welded it in, I found a diagram on here suggesting a length of 74mm v 69mm as standard so that’s what I have now!
    froggy Steve likes this.
  5. Jake the Peg
    206
    139
    43
    Map
    Chris, we are in hope of getting it to Europe this summer, sure one of my Touareg might be comfier and smoother, but there is no fun in that!
    I am considering doing the starter conversion, but it has a new starter fitted, and I will need to change both the batteries, I have the old one from it so might look to get a 100 one and convert the gear and front cover?
    Yeah the paint is rough, but then I don’t worry about going places like I do with the good cars, I’m going to just do all the wear and tear items then it’s my daily, and the family adventure truck
    clivehorridge likes this.
  6. Chris
    16,132
    3,221
    113
    Garage:
    Map
    Spot on.
  7. Jake the Peg
    206
    139
    43
    Map
    So only a little done today, spent some time fixing a power steering leak on my mates 200, but a some parts cleaned up, zinc sprayed and some black topcoat and a clean up in the workshop
    B181FFE9-DE97-499C-B792-A5CE1C17622E.jpeg 29A9264B-AE30-4F76-B643-0606111FB957.jpeg 0E8CF6AD-1715-4E24-85F3-35A27767E7E8.jpeg 28349D05-C364-4B16-82DB-9EB4F338ED32.jpeg
  8. chapel gate
    chapel gate Well-Known Member Supporter Promoted Company I am in england
    3,358
    1,974
    113
    Map
    Thats great news.
    Dont forget new alu washers for the return pipe when you put your injectors back in. Its not worth risking. Being inside the rocker cover on the 24 valve you wont know there leaking until your oil level starts rising..
  9. Jake the Peg
    206
    139
    43
    Map
    Yes, Thanks! I’ll Be changing anything that can cause issues. Is there any reason they use aluminium and not copper washers, I guess there is also a seat washers or the head/ injector?
  10. chapel gate
    3,358
    1,974
    113
    Map
    the two washers are connected, so it combines the washer that sits on top of the injector with the one that sits under the head of the hollow bolt on the return pipe. im mr oem, but I cant think of a reason why you couldn't use the right dimension copper washers.
    im actually putting the head back on a 1hd ft for a customer at the moment so I could grab a pic for you in the morning.
    oh, in a lot of cases the O ring on the injector will tear as you remove it.
    Jake the Peg likes this.
  11. Jake the Peg
    206
    139
    43
    Map
    Yes that would be very helpful, thanks
  12. chapel gate
    3,358
    1,974
    113
    Map
    Alu washers.
    The injectors should come out easily compared to the 12 valve.
    6 mm threaded bar makes a good puller.
  13. Jake the Peg
    206
    139
    43
    Map
    Thanks! Great help, along with the Toyota special tool, I see now it’s not worth the hassle of trying to keep copper washers in place!
  14. Jake the Peg
    206
    139
    43
    Map
    Not too much to show today, backplates cleaned and stone chipped on the inside, new shoes inside, Karsons spring kit and modified dog bones. New caliper slider bolts and the calipers cleaned and zinc’d and topcoated
    @froggy Steve I found with all new parts installed inside 3mm on the dog bone was the max to get it all built up and working good, can’t see it being too hard to get it right, but at 5mm it was too tight to get the discs on . The length on my dog bones has increased from 69 to 72mm
  15. thelal
    thelal Member I am in ireland
    177
    53
    28
    Map
    where did you get the extended dog bones for rear brakes
  16. Jake the Peg
    206
    139
    43
    Map
    @thelal I just modified the original ones, I got an old brake pad and cut a section the width of the slot in the dog bone and welded it in, there was a post on here showing the dimensions but I couldn’t get my disc back on so reduced the extension to 3mm. I have fitted all new parts, shoes, springs and discs. Handbrake is around 4-5 clicks and holds well now
    thelal likes this.
  17. Jake the Peg
    206
    139
    43
    Map
    So most of what I’ll get done this time, new timing belt / kit, new water pump, felt ok while installed but once the coolant was drained the bearing was quite rough, radiator changed, coolant changed, stripped the alternator and cleaned it but I still have a Christmas tree dash, it was full of oil and sheep’s wool and mud!
    All the speakers replaced, nothing from the boot mounted subwoofer, so will take the head unit out and see what’s connected
    Received a couple of nice gifts for it from the previous owner, a pair of front Recaro seats and a front winch bumper, he decided not to bother trying to fit it on his patrol
    3-4 months sitting in the workshop has collected a fair bit of dust, next time home it should should get a day or two under the polisher and the front axle rebuild, new wheels and maybe an mot!
    09C751FE-C07B-422B-B889-FB4C8EBD9650.jpeg 9516BAC0-1B6C-47E8-88D3-40A18A5C4019.jpeg C193060B-24F3-4B61-8EA4-9BF22A72A44B.jpeg
  18. Chris
    16,132
    3,221
    113
    Garage:
    Map
    I like the seats. I'd love to put something like that in mine. Can you cover how you do that please? Ie seat base change over, make from scratch or whatever.
  19. chapel gate
    3,358
    1,974
    113
    Map
    looks much better with that cattle grid removed off the front.
    good shed!
    StarCruiser likes this.
  20. Jake the Peg
    206
    139
    43
    Map
    @Chris The driver seat has been in the truck before, he found climbing in and out constantly a pain so bought a standard seat, I’m a bit smaller than him, and not constantly getting out to chase/worry sheep open gates etc so hoping it will be ok, but I’ll post up my way of installing when I do
    @chapel gate yes much better looking now, the workshop is great, but there are a few furry rodents trying to move back in!
Share This Page
    Dismiss Notice
