With the mot fast approaching, I had to do something with my non existent handbrake.
I replaced the cable a few weeks ago to no avail, then read somewhere you could weld 5mm to the dogbone in the mechanism to space the shoes out more.
Did just that, abit of fettling with the cable, return springs and adjuster inside the disc, and I have a handbrake!
Something to note, the external return springs on the crank arm thing can rust away and fall apart, giving you a loose lever.
If you cant find any for sale you can mod / shorten the one that is inside the mechanism at the top http://www.milneroffroad.com/toyota...s-0/hdj80-brake-shoe-spring-upper-shoe-return
