I am having serious problems aligning the oil tube from the turbo to the side of the engine block so I can fit the banjo bolt…mainly no space and danger of breaking the tube connection to the turbo.I have tried all sorts to do this without removing anything else.!!I have removed the exhaust pipe from the turbo to gain little more space..
Anyone got any tricks or ideas on how to do this .
By the way I had fitted the turbo attached to the exhaust manifold as a unit….which was not easy either as Im working alone!
many thanks for ideas
david 2001
david 2001
