- Mar 1, 2010
My 1995 diesel 80 has a 15L which is seized due to virtually no oil in the system.
I have two 17C's in bits. One is seized but has a good shaft. The other is OK but the shaft is rusty and the seal may leak.
Will the 17C replace the 15L ? Did the diesels get the 15L and the petrols get the 17C ? Karl .............
The picture below shows that the front of the pumps are flush where the pulley will go and the top and bottom bolt holes have the same centres so the 17C should be OK. I must use the old clutch/pulley assy though of the 15L.
The picture below shows all the parts I need for a complete 17C. I have to use the outlet plate off the 15L. Also I bought a genuine Toyota shaft seal to replace the one in the aftermarket seal kit. Other seals in the aftermarket kit should be OK, they have to be as OEM are not available that I can find. I have ordered 134a gas compatible oil which is PAG 46. I'll need 7/8 ounces and I've made sure it has the UV dye in just to check for leaks. There is a front and rear valve body. I have not split them yet to check them as they are a nightmare if I get them muddled up.
Back up to the lab to assemble "Franky".
