Bit of an update on this one after 16 months.
During this summer (well, what was meant to be summer) I started to notice some rusty dust around the General area of the AC compressor and a bit of a swooshing noise. Suspecting the idler pulley to be on its way out, I ordered a new bearing. When I came to pull it off, not bad really, not at all grumbly, just a bit wiggly. So I left it as it was, still wondering what the rust source was. After going to Romania and back, the rust was worse than ever so I phoned an AC compressor supplier (Auto Air of Gloucester) to see if they had a new clutch, thinking mine was worn and slipping. The guy (Paul) was very helpful and said it was almost certainly the coil breaking down and not holding in well enough. He also gave the specs for the coil, 2.8 to 4.4 ohms and the air gap 0.4 to 0.8mm.
So today I stripped the clutch off the nose of the compressor and, sure enough, it looked like the coil had got hot. But there had been a whole lot of rubbing going on. I removed the circlip holding the coil and there it was.
The peg holding the coil from turning had worn into the side of its slot and looked like it had pushed the coil into the pulley, causing it to wear, heat up, deposit plastic on the inside of the pulley and (drum roll please) produce the rusty dust. Hooray!
The even better bit is, I saved the new coil from the new compressor, but what to do about the worn peg slot? More good news, the slot was deeper than the pressed peg on the coil so I decided to extend the peg by tapping it to m5 and inserting a stainless cap head screw, suitably turned down to fit in my improvised lathe.
Once this was fitted, I filed it down so it didn't bottom out in the slot.
And reassembled the coil and clutch back onto the compressor.
Got it all back together, used a socket and piece of ally to seat the pulley bearing fully home as I had to do this with the compressor wedged against the bracket, still connected to the pipework. Bolted it back on then noticed the pulley was rubbing again.
The coil was moving about and allowing the pulley to rub.
I was tempted to leave it for another day but decided to pull it apart again.
It turns out I'd not completely diagnosed the problem. It seems the coil was loose and had waggled back and forth wearing away the Ally at the top of the boss on the nose that it sits on. It had then dropped and made contact with the inside of the pulley and started getting picked up by the pulley. This must have been to do with the circlip being on the wrong way, which I had thought was the right way.
So I cut a tiny piece of steel, coated it with grease to make it stay put, and wedged it between my newly extended peg and the bolt head at the bottom of the slot.
Put the coil back on, nice and solid now sitting in the right place, and fitted the circlip the other way up with the centre pointing forwards against the nose and the outer edge against the coil plate. Nice and solid again.
Reassembled, tightened everything, fitted and tensioned the belt and all was good.
Cut off the connector from the old coil and soldered it to the new coil lead and covered it in heat shrink.
All working again now and, hopefully, no more rusty dust!
