Test using a multimeter on 'ohms' across the solenoid to see that it has continuity. It should show a low value reading if ok. If ok, try connecting 12v across it and see if it clicks and sparks on the terminals. If it spars but doesn't open it's probably stuck internally. If it can be taken apart, remove it to a clean working area and disassemble it for cleaning and testing.
