- Mar 11, 2014
If you can measure the O ring ok, depending on postage cost, might be worth a try for next day from here ?
Catalog - Joint Torique
www.joint-torique.com
I measuredxas best I could but nothing correspond to the sizeIf you can measure the O ring ok, depending on postage cost, might be worth a try for next day from here ?
Thanks. Popped into local John Deere dealer ge had one that's a tiny bit small. I reckon it would stretch over the upper part, and with the fuel resistant sealant / gasket stuff, it might work!I had a leak on my motorbike fuel tank where the sender was placed. Garage used a fuel resistant sealer, never had issues again. Just get the correct sealant and it should be fine,l.
OK Thanks.Will pop into our local halfrauds place (think tiny) to see what they have.Ordinary silicone sealant and diesel don't get on very well together, best if you can find a fuel resistant type.
The filter was a bit crappy, but not enough to block it. I think all the moving cursing and bashing kicked it back into life!Was the filter clogged then ? Good that the pump working now
TBH don't put sealer on an o ring it may well end up in places you don't want it, nothing to gain and a lot to loose. The amount of crop sprayers I have fixed where the farmer thought it was a good idea, must have spent hours pulling little bits of silicon out of valve blocksI've just been into another mower/tractor repair place and they had the exact 'o' ring for the job! I also bought some silicon for deisel fuel so might not need that now! Happy days! Just got to finish cleaning 11 pools and then can hopefully get it going again
I didnt cos it went in all on it's own!TBH don't put sealer on an o ring it may well end up in places you don't want it, nothing to gain and a lot to loose. The amount of crop sprayers I have fixed where the farmer thought it was a good idea, must have spent hours pulling little bits of silicon out of valve blocks
