I know there is a fuse box behind the battery ,but cant find the second one with the ahc fuse ,ive looked in passenger footwell but no look .Its a 2003 facelift model.HELP
Its been a while since I dived into there, but I think there is fuse block either behind the kick panel in the left hand side footwell or on the left hand side of the glove box - you need to remove the glove box to access. But its been a while so not sure. Not sure if the AHC fuses are there.
Passenger side, loosen the "door frame" profile at the front, and one plastic nut holding the kick panel up front. Then the kick panel is loose, and the fuses behind. Well, that's how it is on a LHD...
No need to remove glove box.
Don't know if there's an ahc fuse there tho'
