So after the fun and games with the wheel the cruiser has been running ok, had a nice holiday in the Isle of Wight, Jack thinks it makes a great sunshade.
Lately the smell of coolant has been getting worse, and when parked I get coolant dripping from the drivers side mud flap.
The leaking radiator is back too, it leaks from the crimps near the top hose. I re crimped them, but I think the radiator has been replaced with a cheap pattern part, it just won't seal well.
Got myself a shiny aluminium radiator...
Complete with unions for the transmission cooler, however I will continue to run the transmission oil through the front cooler and use the heat exchanger for the powersteering fluid, instead of the cooling loop that rotted away.
The radiator actually seems good quality, however I will pressure test it before I fit it, and flush it through to try and remove any swarf inside.
The leak appearing at the mudflap is unfortunately the rear heater pipes, I have ordered some new ones, but I think I will have to pull the engine forward to be able to replace them, so I have decided to do some other maintenance at the same time.
Investigate why the A/C won't work,
Replace corroded and weeping powersteering pipework,
Replace transmission cooler pipework (it has EPDM workshop air pipe at the moment which I am worried is not correct),
Fit a V band in front of the Catalytic converters to improve access and to let me rotate them so they sit horizontally,
Replace rear transmission mount which is still repaired with cableties,
Replace corroded oil pressure sensor,
Replace corroded front brake pipes,
Replace load sensing valve (air keeps getting into the brakes)
Fit the front set of axle mount bushes.
Hopefully with these jobs done it will be another big leap forward with the reliability and feel of the truck on the road, I need to get this work done by early October as I need to tow the trials car for the Edinburgh trial.
