Gremlins in the suspension
GeekOKent
120 LC5 with the airbag. I have a weird problem.
My brake light bulb on the rear right went off, but it wasn't just the bulb - the air suspension stopped working too. Replaced the bulb and it's all back again. But again this evening ( after two weeks), the bulb has failed and the suspension has decided to not work at the same time.
Surely they can't be on the same lines, so I am assuming there must be something else going on somewhere ( ? ). And the bulb is just a symptom not the cause. I have been through the most obvious fuses and they are all ok. The batteries are at a good voltage.
I have ordered a volt meter for the cig lighter to see if there is something weird going on with running voltage, but any ideas on where to look for what would be appreciated.
