SteveS
- Jan 12, 2013
Can anyone point me in the right direction regarding the up/down adjuster position for dipped beam. Last time i tried I screwed it up royally. Now that i have the rear springs sorted and with full load there is not enough adjustment on the manual cabin dial to suit loaded/unloaded.
There are two toothed wheels on each - if somebody could tell me where the U/D adjust is FOR EACH SIDE that would be absolutely fantastic. The drawing in the FSM is worse than useless.
As an aside allowing for the beam being a bit low the overall beam pattern is poor.....the kick up and smoothness of pattern on the road is rubbish.....or is that just mine?
Mine is a facelift version late 2003
Thanks in advance
Thanks in advance
