Headlights
Emory1915
australia
Anyone know if 2005 headlights will fit on a 2004? I’m looking for clear headlights but can’t find any for a 2004
I believe the headlights changed mid to end 2005 for the one piece that has integrated indicator unit and had a clear plastic shell.
The later single unit lights don’t fit unless you replace the trim panel under the lights too and possibly other mods.
There was a youtube video about this mod on a 105 series that I remember watching by an Australian guy
Thanks legend that clears a lot up for me.
Depends on production month. According to ToyoDIY, it's the same headlight from 8/2003 until 4/2005 for Europe, and 8/2002 till 4/2005 for Australia. But the UK and the Oz are different.
That’s interesting to know thanks I’ll keep sussing it out
been done I did mine a little bit of work , not a lot but got to change the panel under grill change grill and cut grind part of guard where the indicator sits in it is not much about 2 mm a light trim what part of auzz you from i'm in Vic there is a thread in here some where about doing this did mine about 4 years ago want to know more send me a message and I will give you my email addy the lighting out put is also much better
