Clive I think there is voodoo magic inside there. I'll bet it's platinum infused unicorn eyelashes or something. It transfers the heat very efficiently. Some old barrel strapped to the roof with heating pipes dunked in there probably won't cut it
Clive - loads of good information and sketches on wikipedia if you're going to make one from scratch.
Plan b made me chuckle.
I reckon your plan is sound mate. Good luck.
French I think Chas.
Stu, only thinking out loud. I have a company car for when it's cold and I need to go out early. It was just an idea. Just like the heated washer bottle project..
What is clear is there is tonnes of free heat here. The only bit that you really need a proper bought bit for is the exchanger. I like the free heater one as is flat and easily mounted inn the vehicle. Don't need the rear heater. Pipes are there. Could have a cold water pick up coiled under the seat too to drop straight into a container filled from the river to preserve drinking water supply.
Yes mate I did. it gives me nice hot water. We've actually used it to shower the dog. One thing though, I find that the engine doesn't stay that warm for that long. The video for the product shows Debbie having a lovely shower some time after the engine had run. If I pull up, I reckon I only have 30 - 40 mins to use that heat before it's cooling off. I am probably losing quite a bit of heat in the pipes but not much I can do. I don't know if I am pushing enough of the water around the engine with the pump. I have wondered about putting a bigger pump in the top hose off the rad. Anyway, yes the system works and gives good hot water. My cold water supply goes round the same system - just the temp slider set to cold or the engine is already cold. I am looking at fitting a Y diverter so I can have cold straight from the tank out of the same tap. Just not found the parts yet.
I could move the HE unit to the bonnet and also run cold in from the back but take hot out from under the bonnet too. This would cut down on the travel of hot water, but I don't really want to have water at the opposite end of the truck when I need it really.
I didn't say the water wasn't hot enough Steve. On full, it's perfect. What I meant was that the engine doesn't seem to stay hot that long. If I tried to run hot water an hour after stopping, it would not be hot. But the set up in the video add showed it to be scorching from a normal car engine. We know that tyoically the 80 engine doesn't suffer from poor cooling. Maybe it's that good that when parked it cools very quickly.
