scooby
- Sep 27, 2019
Thank you @Trevor. But would that be better named as a coupling that joins the front drive shaft to the rear drive shaft so as to provide drive to the front axle ? If it does engage a diff. lock somewhere then where is that diff. lock ? Surely a diff. lock locks a differential in which case which differential is it locking ?
